trick flow heads.......
RE: trick flow heads.......
ORIGINAL: foxontheprowl
I got the twisted wedge heads too, I like them quite a bit, though my car does run a bit warmer than it used to and I think it might be due to the aluminum.
Make sure you buy the correct longer pushrods.
VERY IMPORTANT!!!!!! TW's DO NOT work right with stock length pushrods.
trickflow sells the correct ones
Here's some good info.
http://www.totalengineairflow.com/tech/twisthist.php
My 306, a very mild motor by most peoples standerds made over 420 HP on engine dyno this spring.
They have some work done to the ports but nothing real radical.
They will work.......
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
