so is it new
Old 06-27-2006, 03:35 AM
Goosepoop302
Goosepoop302's Avatar
Default so is it new
so when i bought my car they guy said it had a new clutch in it, cna i verify this is any way WITHOUT a ton of work. )if not thats cool ill have something ot do) the one thing is the clutch in the car is unreal stiff(thats ok) i herd that preformance clutches will be like that though???am i full of ****
Goosepoop302 is offline
Old 06-27-2006, 09:01 AM
Tims 88GT
Tims 88GT's Avatar
Default RE: so is it new
take the cover off like u were going to adjust the clutch cable. get a flashlight and start looking.
Tims 88GT is offline
Old 06-27-2006, 09:33 PM
Goosepoop302
....how do i addjust the clutch cable >< sorry not to bright
Old 06-28-2006, 05:37 PM
Goosepoop302
bump
Old 06-28-2006, 06:02 PM
philthy89fifty
philthy89fifty's Avatar
if you have the stock quadrant setup you just lift up the clutch pedal untill you hear it click and your done.
philthy89fifty is offline
Old 06-28-2006, 06:13 PM
gspfunk
gspfunk's Avatar
I think what you're trying to find out is where the clutch fork cover is....
Driver's side of the car, look up on the side of the tranny. You will be able to see where the thick, black cable (clutch cable) goes into the bellhousing. The cover is right there (usually black). You need to remove the screw on the bottom, slide it a 1/2" towards the back of the car, then pull down and out. It should come off pretty easily, but sometimes the seal gets sticky, so a screwdriver may be needed to seperate it. shine a light in there towards the back of the engine and you'll see the clutch and PP. You're on your own from there as far as trying to figure out what brand it is.
gspfunk is offline
Old 06-28-2006, 07:38 PM
tncruiser
tncruiser's Avatar
youve put 20 k on the clutch so hard to say if it was new 20k ago when i was a kid i went thru 4 clutchs on my 64 comet 1st three under warranty , then after 12 k i had to pay for my own,god i wish i was 17 again "tearin up new cars"
tncruiser is offline
Old 06-28-2006, 08:21 PM
88stangaruu
88stangaruu's Avatar
you can see if it looks nice and new. THe pressure plate i mean. Other than that, no real way to tell until you pull the tranny and bellshousing and take the pressure plate off.
88stangaruu is offline
Old 06-29-2006, 07:55 PM
Goosepoop302
ORIGINAL: philthy89fifty
ok so if i just pull the clutch pedel up as far as it goes...and if it clicks its stock??? guess i dont FULLY understand what you mean
