fuel gauge
fuel gauge
hello i just bought a blue 88 notch. i first came on here to introduce my self but secondly need some advice i have tried searching but no luck. my fuel gauge in the car does not work. can someone give me some advice of where to start to look to see what the problem is. thanks alot
andrew
andrew
RE: fuel gauge
Use the following diagram extract....Courtesy of TMoss and Veryuseful.com
You would have to do a resistors check by splicing a 145 ohm resistor to the yellow/wht wire, and shorting the other end of the resistor to a good ground....turn ign on and the gauge should read "Full".....if it does, the sender needs to be replaced, if not the "anti-slosh" module might need to be replaced
....this is a module that goes inserted or bolted-on to the instrument panel module. Hope this helps
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
