Weird vibration...?
Weird vibration...?
OK, i finaaly got my car running right and all alligned and set to go. Runs good, rides real nice and is perfectly smooth even at 90 mph...at least when i am in gear. When I let off at around 80 (this doesn't happen at 65 or even 75,) theres a vibration that you can feel and hear though its not bad, but if I push in the clutch on the highway at those speeds it gets real loud and more noticable, and i'm not sure what it is. Any ideas? THanks guys.
the other killa
the other killa
RE: Weird vibration...?
could be some excess backlash in the rear end gears that gets worse when you take it out of gear and the engine drag on the gears goes away letting them freewheel and rattle back and forth due to extra clearances.
If your using a Standard trans it could even be Thrust Bearings on your crank. I used to run a Very strong clutch on the street, and did too much city driving and it cost me. I worn out the Thrust bearings. How you can tell is Have someone Look at your lower pully and then you press in your Clutch. If the pully moves then thats what the problem is. Keep us posted
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mungodrums
09-28-2015 10:54 PM
