Pulling Trans, Any Surprises?
RE: Pulling Trans, Any Surprises?
An auto isn't that bad. I did mine myself. The hardest part is the top 2 bolts but loosening the motor mounts and letting the motor tip back makes them easy to get with a long extension.
yeah surprises are there!
your EXHAUST WILL BE RUSTED and hard to get off the headers. Its best to grind off the studs and replace with nut and bolts/ washers from hardware store.
2. drain the tranny fluid from the pan. soak driveshaft bolts with rust penetrant. I caught HELL REMOVING EXHAUST FROM HEADERS.
Matt's 95 Stang
10-05-2015 07:16 AM
