Starting Issue
Old Jul 10, 2006 | 06:55 PM
Keeler's Avatar
Keeler
Default Starting Issue
1988 5.0 Mustang. It drives great and no problems when it runs. However when I drive it for a while sometimes or drive it hard, I'll turn it off, come back out, turn it on and it'll start right up but then kind of "Chugs" instantly like it's not getting fuel or losing cylinders. Then it'll die, it won't start for a while or when it does it'll have the same symptoms. If I let it sit for 20-30 minutes, and then start it again, it fires right up like nothing happened. I've replaced the coil, distributer cap, plugs, plug wires all recently. Fuel Pump, filter, and line was replaced about 5k miles ago. I'm not sure what it could be and any insight would be great...Thanks ahead of time.
Old Jul 10, 2006 | 07:01 PM
JenniferJ's Avatar
JenniferJ
Default RE: Starting Issue
I know mine is not a 5.0.. I have an 01 GT and it does the exact same thing! It's damned embarrassing at times! I have to sit there and wait until it decides to run. I wonder if there is something in common?
Old Jul 10, 2006 | 07:33 PM
schwindty's Avatar
schwindty
Check your timing, change tyour TFI Module on your distributer, pull codes
Old Jul 10, 2006 | 07:37 PM
Keeler's Avatar
Keeler
Timing is good, I've heard of the TFI module but wasn't too sure if it could be the reason.
Old Jul 10, 2006 | 07:46 PM
schwindty's Avatar
schwindty
Cheap to replace, code reader is your best bet should tell you if anything is out of order.
Old Jul 10, 2006 | 07:50 PM
mattkoly's Avatar
mattkoly
+1 on the TFI module
Old Jul 10, 2006 | 08:02 PM
Keeler's Avatar
Keeler
Where is the best place online to pick one up? Also what will I need to replace it, any special tools?
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
5.0 kevo
Sep 3, 2015 06:24 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
