a/c clutch problem?
a/c clutch problem?
Last summer i changed from r12 to 134. while doing so i got a new compressor and clutch. now when i go to use my ac the clutch is not engaging. it was brand new last year. could it have gon out already or is it maybe an electrical problem????????
RE: a/c clutch problem?
ORIGINAL: 90stang50
if not, there's your problem. You burned out your compressor.
could be low on refrigerant, could be that a pressure switch popped. could also be that the clutch gap between the compresser pulley and the clutch is too big, and the coil behind the pulley wont pull the clutch in. or just a bad coil.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
