How to bypass egr valve??!!
Old Jul 14, 2006 | 02:55 PM
92hatchLX's Avatar
92hatchLX
Default RE: How to bypass egr valve??!!
Mine is 42 with the vacuum off, 39 with vacuum on. I guess I need to sell this one and get a mallory or something that is a little bit more low profile.
Old Jul 14, 2006 | 04:24 PM
vristang's Avatar
vristang
Obviously there is a range of what the stock regulators would put out from the factory.
All the inspection things I have found have focused around the 40 range.
Silver91-
If you are running slightly rich at 30psi, then I think you have another problem that needs to be sorted out.
The computer assumes ~40 psi, so you need to be somewhat close to that to have accurate fuel metering.
Maybe the MAF is not calibrated correctly?
Have you checked codes?
jason
Old Jul 14, 2006 | 05:11 PM
5.0stanger's Avatar
5.0stanger
My fuel pressure with the vacume on is at 34 and with it off it is at 40...is that a problem?? I removed my EGR with a block off plate I made and just left the sensor on(took it off the valve) and glued it in about half way...no problems yet and it cost nothing
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
