Throttle Body? Or something else?
RE: Throttle Body? Or something else?
yes try tps is the throttle position sensor, hey guys tell me what to adjust or what to do please, i have the same porblem after i installed a cold air intake, explain to me in detail what i have to adjust, thanks a lot guys!!!
It's on the throttle body and is black. There are two screws that hold it on. What you need to do is loosen the screws and swivel it to adjust the output. To read the output put the positive lead from a multimeter on the green wire coming out of the TPS and just ground the negative. You can either stick a pin in it or backprobe the connector for the green wire. You may have to lengthen the screw hole to get a proper reading. Just get it adjsuted between .9 and .99 volts at a closed throttle position.
