Installing Intake..Cam???
RE: Installing Intake..Cam???
Just take your time make sure you do the torque sequences and make the surface real clean . Just did mine, may want to replace heater hoses and bypass hoses th.body coolant hoses while it is apart. also marking everything is a great idea if you are not familiar with cars.
if you did your t/b and exhaust you should be able to takle the intake swap. not too bad of a job. make sure you change your oil after b/c you get coolant in the lifter valley. i would flus the radiator too.
09-10-2015 08:39 PM
