G TEch computer need help!
Old 07-17-2006, 03:24 PM
number1_kid
number1_kid's Avatar
Default G TEch computer need help!
Hi.
I bought a G-Tech pro SS in May
Tried in my 87 GT few weeks ago.
work all good.
Programmed it right and calibrated RPM right on the dot.
Now today I go to do it and RPM does not go over 2500 on the G-Tech but on the car's gauge all works good.
SO I re-do on the settings again.
Still does the same.
I went right after and tried it on my friends civic did all his settings and went to do a few runs.
All was 100%
So I got and re-do the setting for my car and it dont work.
So I am thinking something is screwed with the 8 cylinder setting cause rpm does not go over 2500RPM
Then after the RPM calibration it ask you to choose the closest setting .
I did that and still the same problem.
So I decided to take this further
Tried in my moms echo.
Work 100%
Tried in my dads 6.0L chev
still stays at 2500
So now I know its the computer.
Anybody had this problem?
Now I will tried for a warranty
Any luck with that guys?
number1_kid is offline
Old 07-17-2006, 03:55 PM
88BlueGT
88BlueGT's Avatar
Default RE: G TEch computer need help!
Im not exactally sure why its doing that. Did you just erase all the data in the G tech and completly start over reduing ALL of the calibrations for the Stang?
I would try that first. I have no problems with mine on my 93 GT
88BlueGT is offline
Old 07-17-2006, 03:57 PM
number1_kid
how do you clear all the data?
I have erased the saves runs.
And re entered the calibration and weight.....
Old 07-17-2006, 03:59 PM
88BlueGT
88BlueGT's Avatar
Im not sure what other calibrations there are on there but I know there are more... theres the axle calibration, rpm's, weight, etc.
Also, did you make sure that the g tech was level? Im not sure but that could possibly throw some readings off causing it to not work...
88BlueGT is offline
Old 07-17-2006, 04:00 PM
number1_kid
like I said
all is working on other vehicule using all the same methods I use
Except on 8 cylinders
Old 07-17-2006, 04:01 PM
91lxstang
91lxstang's Avatar
lately ive heard that these things dont work very good anyways but i dont have any experience with em'
91lxstang is offline
88BlueGT
88BlueGT's Avatar
hmmmmm...... im not sure than. Mine works fine on my 93 GT but I have a regular G Tech.... not the SS. Im not exactally sure on the differences between the two.
88BlueGT is offline
Old 07-17-2006, 04:03 PM
number1_kid
ok thanks guys
I sent email to G tech
sent exactly what i wrote here
So they wil tell me whats wrong or about warranty.
probably take a month for a reply
but
if anyone on here no what i can do please let me know
thanks
EZFEED
05-05-2016 08:54 PM
piotrek53
10-13-2015 06:54 PM
firecoyote
09-27-2015 02:37 PM
mltdwn12
09-23-2015 08:54 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: G TEch computer need help!
