gear installation cost?
#23
RE: gear installation cost?
I doubt you need a rebuild kit..I would however install a new clutch pak and would just replace the axle seal and pinion seal
ORIGINAL: chath_brick
ford racing 3.73s: $144.88
installation kit: $125.39
drive gear: $15.00
speedo gear: $12.00
total parts: $297.27 shipped
drive gear: $15.00
speedo gear: $12.00
#24
well, i got the rebuild kit because i can hear one of my wheel bearings grinding, so i figured if i'm going to be in the axle anyway i might as well rebuild it. plus i'm going to be reefing the **** out of it with those 3.73s in it, so i figured it could use a freshening (it has 100K on it)
#29
94 cobra kid: https://mustangforums.com/m_1322654/tm.htm
i had the same question, you'll need to change out your drive gear as well, go with a 6T/18T, that will be perfect (see why in that thread)
and 91lx, i LOVE your sig, that fat kid is hilarious
