Distributor install problem
Old Jul 19, 2006 | 12:14 AM
cioccoj's Avatar
cioccoj
Default Distributor install problem
My son has a 1989 5.0. We recently bought a GT40 upper and lower intake. I installed it this afternoon and went to put the distributor back in and it didnt want to go. I looked down into the motor and saw that the oil pump shaft wasnt centered in the hole. I spun it with a socket and still it didnt straighten out. I then took it out and checked the shaft for straightness and it seems fine. I put the distributor in without a problem without the shaft in just to see if the problem was in the dist. I put the shaft back in and still have the same problem. The dist. goes over the shaft maybe an 1/8 of an inch and wont go any further due to the shaft not being centered. It was in the car and operating fine before i took it out. My question is, does the shaft go in a specific way, or is there some Ford trick that im not aware of. Thanks in advance.
Old Jul 19, 2006 | 12:30 AM
duslep's Avatar
duslep
Default RE: Distributor install problem
When i put in my new distributor i replaced mine even though it wasnt bent because i was facing the same problem.
Old Jul 19, 2006 | 12:34 AM
hellas85stang's Avatar
hellas85stang
an old trick is to put a dab of jb weld in tip of rod and stick in distributor end and let dry..u can stab it in oil pump easier some times ...turn motor over a few time look at oil pressure and see if u have good pressure...
djbigskrilla
Sep 20, 2022 01:04 AM
Jskeezy84
Sep 8, 2015 01:40 AM
1987gt40ttopt
Aug 28, 2015 10:49 PM
microgt
Aug 20, 2015 07:12 AM
jjwinel78
Aug 17, 2015 03:34 PM
