**Drag radials**
**Drag radials**
my freind has 93 lx hatchback with a full intake exhaust and gears and hes looking for some input on how big he can go on a set of rims and drag radials looking for some serious traction how wide can he go without them sticking out too far or rubbing? some help pleeease terrible 60 foots cant go ful throttle in first or second!!!
RE: **Drag radials**
Sounds to me like some suspension mods would be in order and THEN do the rims and tires, you dont need insane meats to hook up necessarily. WHen I was EFI and the car ran really hard, I hooked very well until about 4500rpm and then it would start spinning, but off the line it was great.
4-way struts
50/50 drag shocks
new quad shocks
full length weld-in subs
tq box re-enforcement kit (in case I run slicks later)
4.10 gears
strut tower brace(not needed)
stock 88 GT springs (replaced the one's in the rear b/c they had started sagging a tad
I ran the stock turbine rims and 245/60/15 cooper cobra GT's (crappy)
car hooks semi decent.
4-way struts
50/50 drag shocks
new quad shocks
4.10 gears
ORIGINAL: 2 kwik
why would you use 17" rims as your adding rotating mass so the car is slow and another them there is less sidewall for traction
a 275-50-15 will work nicely
