92 idle problems
Old Jul 23, 2006 | 11:37 PM
stacynwes's Avatar
stacynwes
Default 92 idle problems
Im having a wierd idle issue my idle jumps around from 1300-600,back to 1300-700,then it seems to mellow out around 1000rpms and idles around 950 so if i go down the strret and get on it hard it start doing it again its more like a pulse like whomp,whomp,whomp and the starts to mellow down.any ideas?thanks wes
Old Jul 23, 2006 | 11:57 PM
5.0stanger's Avatar
5.0stanger
Default RE: 92 idle problems
Start by cleaning your IAC.
Old Jul 24, 2006 | 12:09 AM
stacynwes's Avatar
stacynwes
I cleaned it already.and it has all new throttlebody/egr spacer.but it was doing that before.
Old Jul 24, 2006 | 12:11 AM
5.0stanger's Avatar
5.0stanger
You check your TPS voltage lately?
5.0stanger's Avatar
5.0stanger
what year and what mods?
Edit...its a 92, what mods then...
Old Jul 24, 2006 | 12:12 AM
92hatchLX's Avatar
92hatchLX
try and set your tps and clean that MAF sensor. A dirty MAF causes 90 % of idle problems on these 5.0's.
Joel5.0's Avatar
Joel5.0
Suggested to-do list:
- Resetting the base idle
- Setting the TPS voltage (Setting it between .8vdc - 1.0vdc is OK)
- Timing calibration
- Finding possible vacuum leaks.
- DIY KOEO/KOER Self-Tests and Cylinder Balance Test
and if the above link to m-y-5-o-h-.com still doesn’t work, use
- How to run a KOEO, KOER Self-Test codes scan and Cylinder Balance Test, instead. LUK the results.
Old Jul 24, 2006 | 12:22 AM
stacynwes's Avatar
stacynwes
cars is a 88 4 to v8 conversion with a 92 motor,was a speed density car but now mass air,I have a 93 cobra manuel computer,70mm mass air sensor,brand new 70mm throttlebody/egr spacer,ported intake plentuim,24lbs inj,cold air , a adjustable fuel regulater,c4 manuel body with 2500 stall,373 gears,flows and the supercharger is on its way,but i was hoping to get these bugs out first.now adjusting the TPS what voltage and howdo i test it.and its new also came with my throttlebody.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
