How the **** do you pull off the crankshaft pulley!?!?
RE: How the **** do you pull off the crankshaft pulley!?!?
I dotn know if you need one of those or not. Thats a harmonic balancer puller. If you have a huge 3 jaw puller put it on the pulley and try getting it off that way. If you've got a mirror look into the oulley and see if you have all the bolts removed.
No man, I got all 4 bolts out.
What about dousing the damn thing in acid? Maybe it's rusted together?
It's a stock balancer as far as I know, looks exactly like one.
I wish i could see what one looks like as i'm drawing a blank atm, but i think you might just for the heck of it try and see if you can get a standard screw driver under it On the inside and work it around like you would to pull a tire off the rim but then again I'm half asleep lol i could be wrong
Have you tried any liquid wrench or pb blaster? If you have a pick you might be abel tog et that under there and spread it enough to get a screw driver in there.
FINALLY got it off, we took a chisel and blasted it from the bottom a few times.
Came out after a few decent hits. Everything looks ok, pulleys on, next step, alt out, headers, new alt in , + more.
Should be done by later tomorrow. Taking pictures of everything.
