fuel pressure regulator
Old 05-24-2004, 08:44 PM
badexample
badexample's Avatar
Default fuel pressure regulator
Is there a way to bypass the stock fuel pressure regulator? What would happen if I just disconnected it all together? Just wonderin cause my 86GT is runnin lean and I dont really have the money to buy an aftermarket regulator.
badexample is offline
Old 05-24-2004, 09:11 PM
bmorrisj
bmorrisj's Avatar
Default RE: fuel pressure regulator
im sure something would burst...you would be going max pressure at all times and probably cause the injectors to leak, causeing your fuel mileage to go to crap...
bmorrisj is offline
Old 05-24-2004, 09:15 PM
86HOGT
86HOGT's Avatar
NOT a good idea. They put it in for a reason.
86HOGT is offline
Old 05-24-2004, 09:31 PM
badexample
badexample's Avatar
Sounds good to me. Ill take you guys word for it. I kinda still need my fuel injectors at this point.
Old 05-25-2004, 12:03 AM
VertStangGT86
VertStangGT86's Avatar
Either you'd have to plug the return line or have it go straight to the return, either way bad idea and things won't work. Bottom line if you're not getting enough fuel for your engine and it's all in working order you need an adjustable reg.
VertStangGT86 is offline
mrtrodonet
09-19-2020 03:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: fuel pressure regulator
