t-5 trans id
t-5 trans id
I have a t-5 trans. the tag is missing . i found two numbers on the trans housing 1352-???-921 and 1352-???-939. these are cast in the housing. i forgot the middle numbers. it is suppost to be out of a 92 gt. i checked the id chart from ford muscle. i'm thinking the numbers on the housing are not id numbers pertaining to the year. thanks joe
RE: t-5 trans id
yes, those are just the casting numbers.
double check the tailshaft of the t-5. the tag is on the upper part. you may see better through the trans hole while sitting in the car.
use a mirror too.
look for the end of the trans, then look for a ring of bolts about 2-3 inches in front of the shifter. those should be the trans tailshaft to transmission bolts. the tag is mounted on those.
use a mirror too.
Matt's 95 Stang
10-05-2015 07:16 AM
