Best stroker 331 vs. 347
RE: Best stroker 331 vs. 347
ORIGINAL: LX 90
so what im basically seeing is get a dart block because they are stronger and get a 331 stroker kit from likee dss or whereever??
ORIGINAL: LX 90
whitch one and who makes the best???
I'm still debating this topic my self. I going towards a 331 just cause of a bit longer life span then the 347. What I want to know if anyone here knows are numbers. How much HP can I get from a 331 N/A and the number for a 347 N/A?
Here's where I'm getting my stroker kit from for those who are curious http://www.strokerkits.com/ford_stroker_kits.htm
The DSS is not stock if you get the super pro bullet or Xr those are 650 and 1000 Hp rated
ORIGINAL: 88BlueGT
^ +1 w/ Full Auto. I think you are getting confused. A DSS block is still a STOCK block and will still be limited at 550rwhp (give or take). A DART block will run you about 2K easy with nothing in it (no crank, pistons, etc. etc.). Than add the $1,300 for a stroker kit and you have yourself a shortblock for about 3.5K.
