window problem
Old Jul 25, 2006 | 02:08 PM
88MustangGX's Avatar
88MustangGX
Default window problem
ok here's a good one. pass side window won't go up. started on sunday morning however by the afternoon it went up again like nothing was wrong. last night i tryed it and got nothing. no noise from the motor or anything. switch maybe? should i take the door panel off and start pokin some wires with a test light maybe? thanks
Old Jul 25, 2006 | 02:30 PM
86 GT 5.0's Avatar
86 GT 5.0
Default RE: window problem
i had the same problem and i hooked up the test light and everything and it happened to b the actuator
Old Jul 25, 2006 | 02:46 PM
Boss_Hotrod's Avatar
Boss_Hotrod
You might want to check your window motor bushings. A while back our driver's side wouldnt go up unless you cranked the car. It did it again the next time I went to wash it but it wouldnt go up period. We took the motor out after determining it wasnt the switch and noticed that the bushing were shot. The motor turned when we had it out of the door but just barely. We replaced the bushings and it performs better than our newer cars. You can get them from 5.0 resto for $6. Id recomend redoing both windows while you were at it.
Old Jul 25, 2006 | 03:01 PM
5.0 MPG's Avatar
5.0 MPG
if your not getting any noise from the motor its deffinately an electrical problem. its more than likely that switch going out. take the panel off and move those wires around to try and isolate the source. do the same thing with the wires going to the motor.
Old Jul 25, 2006 | 03:28 PM
88MustangGX
well the funny thing is that neither switches work. pass and driver side don't do ****.
Old Jul 25, 2006 | 03:45 PM
7upedition's Avatar
7upedition
motor may be burned out... could be a loose wire have you removed the door panel and visually inspected the window motor, if niether switch works then its gotta be motor related, do the other windows operate from the drivers side switch panel?
Boss_Hotrod is most likely right.
Old Jul 25, 2006 | 04:14 PM
88MustangGX
ORIGINAL: 7upedition
yea both switches are on the driver side. neither switch works.
Old Jul 25, 2006 | 04:19 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
mine wouldnt work 1 day and i didnt even mess with it
came out the next day and it worked?? hasnt stopped working since lol
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
