IAC question
Old Jul 25, 2006 | 10:39 PM
stacynwes's Avatar
stacynwes
Default IAC question
my question is if you go from a stock throttle body to a 70mm throttle body will your IAC still work right.Here is my deal a bought a 88 coupe that was a 4cyc converted to a speed density V8,I converted it to a mass air.And basicly I went with a 89gt A9L 5 speed computer,70mm,throttlebody/egr,70mm mass sensor,24lbs injectors,adjustable fuel regulater set for about 35lbs at idle and 40 when you gag it.I had a crazy idle jumped or pulsed.so everyone was telling me to clean the mass air,and the IAC,so i cleaned the mass air and bought a new IAC,the TPS is set at .98-1.0volts.and still the pulse.its not a vaccum leak theres only 4 or 5 vac lines and Ive looked them all over no leaks.Plus a vac leak would give it a rough idle not a 500 to 900 rpm pulse.any help will be great.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
lmurf60
Sep 24, 2015 10:07 PM
