Quick Question
Old Jul 26, 2006 | 01:46 AM
Greedy's Avatar
Greedy
Default Quick Question
Alright so I borrowed my brothers flywheel and clutch because mine went out and he accidently orderd one with his 347 stroker. So I put his 347 flywheel and clutch in my car and it viberated leading me to believe that its not balanced correctly? Would the fact that the clutch and flywheel are balanced for the 347 motor make it viberate? If I take in my old flywheel and have it turned will it work with the new centerforce clutch. Is there a difference between a 347 and 306 clutch?
Old Jul 26, 2006 | 01:48 AM
duslep's Avatar
duslep
Default RE: Quick Question
im no expert but the clutch should be fine as long as it is for the 302 block and the t-5 tranny. I would lean more towards the flywheel being the wrong weight or unbalanced or something along those lines
Old Jul 26, 2006 | 01:50 AM
88scgt's Avatar
88scgt
your brother may have ordered a diff weight flywheel. there are two diff ounces for foxs and it could be a 28 oz or a 56 oz . check the weight
Old Jul 26, 2006 | 01:52 AM
randy78045's Avatar
randy78045
ORIGINAL: duslep
Im kinda thinkin the same... and is the clutch the same diameter as your stock flywheel... [:-]
Old Jul 26, 2006 | 01:58 AM
Greedy's Avatar
Greedy
Ok i think its probably the wrong weight i remember readin somewhere that most of the time 347's are 28 OZ, mines prolly not causeing the vibration... I hope they are the same diamiter I'll have to check that tommorow when i pull it all back out. What weight do you think a 306 flywheel is?
Old Jul 26, 2006 | 01:59 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
the 347 is going to be balanced differently from your 306. of course its going to vibrate. get yours machined and you can use it with the clutch. find out what the weight of the flywheel is though, and the brand. if you wanna get rid of it i might be interested if its aluminum and a 28oz balance.
Old Jul 26, 2006 | 02:03 AM
Greedy's Avatar
Greedy
k that makes sense, i never thought of it....till it was viberating. i was just happy as hell to get it all back together again. I know it not an aluminum one, not sure of brand.
Old Jul 26, 2006 | 02:04 AM
mrbigshot's Avatar
mrbigshot
347 is 28oz (as a 347 is a 351c crank cut down)
metric 302's (5.0's) are 50oz
tmdm
May 2, 2021 02:49 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
