Cam in a '94-95 5.0- problems with idle?
Old May 28, 2004 | 04:33 PM
68silvercoupe's Avatar
68silvercoupe
Default Cam in a '94-95 5.0- problems with idle?
I have heard that putting a cam in a 94-95 5.0 gives it a bad idle. Is this true? I have a 95 5.0 from a truck with a trick flow cam: .498/.512 what can i expect when I start it over? Thanks
Old May 28, 2004 | 04:35 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Cam in a '94-95 5.0- problems with idle?
hehe changing the duration and lda of any cam in a motor will change the idle. the lift isnt that aggressive - but lift doesnt affect your idle. whats your duration and lda?
Old May 28, 2004 | 05:00 PM
primetime5.0's Avatar
primetime5.0
you can put a different computer from the 93 mustang in it to fix the rough idle problem
Old May 28, 2004 | 08:36 PM
86HOGT's Avatar
86HOGT
It's a bad thing that the 95 truck motor you have isn't a HO, but has the HO firing order and 185HP with stock cam.
Old May 29, 2004 | 12:20 AM
D1g1tal V3n0m's Avatar
D1g1tal V3n0m
I ♥ Acer
Stock cam in the 5.0s aren't bad. Seen 10's with them before.
The Alphabet cams from Ford are more prone to idle problems. Steeda's #18 and #19 cams are supposed to be the best and no idle problems.
Don't need to do the A9L swap into the 94-95s anymore. That was done because nobody at the time could reflash/tune them. Now they can so get it reflashed or tuned. Best way to do it.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Luke9222
Sep 4, 2015 06:46 AM
Emblazoned
Sep 3, 2015 10:45 PM
