3mpg???? PLEASE HELP
Old Aug 2, 2006 | 04:48 PM
Pearlkobra12's Avatar
Pearlkobra12
Default 3mpg???? PLEASE HELP
K so i just ripped out the engine and cleaned up some leaky areas and put it back in the 1986 mustang gt. I drove it yesterday and the gas mileage is horrible. 60 miles on one tank.... so like 3 mpg. i k the engine is pushing way to much fuel into it cause at and below around 2000 rpm the car chugs really bad. i am new to fuel injection and so i just dont know what to do. I need to drive the car to work daily and at this cost i wont be able to much longer. what should i do???
Old Aug 2, 2006 | 04:49 PM
88stangaruu's Avatar
88stangaruu
Default RE: 3mpg???? PLEASE HELP
sounds like you need to turn the Fuel pressure down. Do you know whats its set at?
An injector may be stuck open or something like that also.
Old Aug 2, 2006 | 04:52 PM
Pearlkobra12
no i have no idea what its set at .. i'll check in a bit. whats a normal level?
Old Aug 2, 2006 | 04:53 PM
mustangchippy90's Avatar
mustangchippy90
yea, if you don't already have a adjustable fuel pressure regulator, get one and have you or someone install it with a gauge. I have one and if you turn it up too high, you'll run too rich and it'll do that. stock psi on the fuel lines is like 39. I turned it down before and I got better gas mileage. But it might be somethin bigger like he said.
Old Aug 2, 2006 | 04:55 PM
88stangaruu
i got 24# injectors and i run 38 at idle and around 42 at WOT. I played around with it for along time, but that seems to be where my car likes to run, right around in there. Plus my car runs a tad bit rich, where it should be.
Old Aug 2, 2006 | 05:08 PM
Pearlkobra12
alright. i k i dont have a gauge so this could be tricky. would advanced auto parts or napa have something i could put on or am i gonna have to order one
Old Aug 2, 2006 | 05:34 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
get an adjustable regulator and a gauge
shouldnt be more than $200 for both and any auto parts store should have em
Old Aug 2, 2006 | 05:35 PM
lookinforastang
I ♥ Acer
also might want to keep in mind that your gas gauge could be off too
i'd drop the tank and take a look at the sending unit
if its off even a little bit the gauge will read very messed up
Old Aug 2, 2006 | 05:41 PM
7upedition's Avatar
7upedition
put the car on jack stands, rest your foot on the gas pedal and drive it until the motor stops, then you'll find out how many miles you really went, chances are your guage is shot or the fuel regulator/fuel pump is messed up. what injectors are you running?
Old Aug 2, 2006 | 06:39 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
ORIGINAL: 7upedition
your not serious?...there is no load on the engine so no way can you find out mileage
