Rockers/Heads
Rockers/Heads
I'm looking at the AFR 165 heads and wanted to see what rockers you guys would go with, if you had my setup. 1.6 or 1.7 and what brand. Also would you got with 58, 60, or 61 cc?
Thanks,
Thanks,
RE: Rockers/Heads
Stock cam, but eventually I'm going to get a custom grind from Camshaft Innovations.
I did see I'll need to get the pistons fly cut for the AFR heads.
Would you go pedastal or stud mount rockers and 1.6 or 1.7?
Appreciate your input.
RE: Rockers/Heads
run the 1.6's and have Camshaft Innovations build you a cam to your specs. they'll give you a nice lift, so you wouldn't need the 1.7's.
actually scratch that. Call them up first, ask them.
