H-pipe to header bolt up headaches
RE: H-pipe to header bolt up headaches
I totally disconnected the H-pipe and just had it hanging by the pins.
The header to h-pipe bolt up was the biggest PITA to me. After the midpipe is just hanging there it's pretty easy to manipulate onto the header flange. Leave both headers kinda loose also, so that there's a little play in them without the bolts coming out.
just feed it back and forth slowly tighten all the bolts a little bit at a time back and forth,and yes a jack does help....arms get tired unless you are a monkey
***** IT!!!!!!
Took up to gas station down the street ........ 30mins and $30 had them hook it up
Ran like shyt on the way home, but havent done timing
or fuel pressure yet. Really bad idle and stalls out
Let you know....................
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
