Injector Procedures
RE: Injector Procedures
I still don't get it.
You said you swapped the injectors and asked if there's a special proceedure. The answer is no, there's no special proceedure.
I then added, if you swapped to the same sized injectors, there should be no problems. If you swapped to larger size injectors, you'll need an air meter with the correct calibration for those injectors.
ORIGINAL: Mike92
Thanks
TfcCDR
09-14-2015 12:08 PM
