AFR 185 vs 165? Opinions Please.
ORIGINAL: 1994sn95
ok i decided my choices were the afr 165 or the trick flow top end package. I compared the two heads and it turns out the twisted wedge actually flow more than the 165's, and the intake and exhaust valves are the same size. So im almost certain i will be goin with the TF package. I should be ordering in the next couple weeks. I will let you guys know how it runs.
You bet, might want to put a more s/c oriented head gasket on than what
comes with the Trickflow kit though.
ORIGINAL: 91LXStang2727
Is the trickflow package good or ok to have with a blower?
AFR FOR THE WIN!!! GO BIG OR GO HOME! I got 185's on a 306. Bought it that way and it did have a bigger cam in it at one time so im sure the pistons are cut. Get the 185's and when you get the windsor, you will blow away the TW heads.
