NEED HELP
ORIGINAL: 16FoxBody
its a 92. Ok so i have tp spin the crank so that grove and timing dot are at 12 o clock, the cam gear, the little notch or point thing should be at 6 o clock and the cam gear should slide over that and have it sit at 6 o clock. then attach the chains and i should be all set?
ORIGINAL: 16FoxBody
does it matter that i spun the motor over with the dist out?
Ok well i took my cam out, put it back in so the little timing bar is at 6 o clock, put the cam gear on, put the little bar inside the little hole on the gear, spun the crankshaft so the little grove and dot are at 12 o clock, put the the TC on, spun it over and the same thing happens, i really dont get it anymore
