Alignment
Old Aug 15, 2006 | 02:57 PM
83gtragtop's Avatar
83gtragtop
Default Alignment
Just finished installing springs/shocks, mm caster camber plates and am going to go in today and get the alignment done. What do you guys recommend for caster and camber settings. My car is for the street only and so nothing very aggresive. My BFGoodrich tires cost me a pretty penny so i want to get as many miles out of them as possible.
Thank you,
Brian
Old Aug 15, 2006 | 03:05 PM
JeffUtica's Avatar
JeffUtica
Default RE: Alignment
Tell them to set the alignment to '93 Cobra specs. I believe they have slightly more + camber for better handling as compared to stock fox body cars. In fact ask them to show you what the differences are. With caster/camber plates you can even increase caster for addition handling improvement.
Old Aug 15, 2006 | 03:12 PM
83gtragtop's Avatar
83gtragtop
I can def. increase caster with cc plates. So increased caster will not effect my tire wear? I just want to keep the camber close to stock, to avoid uneven wear.
Old Aug 15, 2006 | 03:27 PM
86HOGT's Avatar
86HOGT
Caster does not affect tire wear. More negative caster will make it more stable at higher speeds. You do not want any positive caster. Personally I'd want the camber to be right at zero.
Old Aug 15, 2006 | 03:42 PM
83gtragtop's Avatar
83gtragtop
Camber at 0, thats what i was thinking or no more then -.5 degrees.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
