please help? no start when hot........
Old Aug 17, 2006 | 12:23 AM
gixxer1's Avatar
gixxer1
Default RE: please help? no start when hot........
ok checked my tps volltage with key on closed throttle. 00.01 full throttle 00.09v my computer must be bad huh? probed black and green wires.........
Old Aug 17, 2006 | 01:04 AM
vristang's Avatar
vristang
ORIGINAL: gixxer1
I hope those voltages are mis typed
that does not look right.
This is with the engine running?
Old Aug 17, 2006 | 01:18 AM
gixxer1's Avatar
gixxer1
engine off key on..........00.01 volts closed throttle..........00.09volt full throttle........black and green wires probed.
Old Aug 17, 2006 | 08:39 AM
REDS 5.0's Avatar
REDS 5.0
Those numbers are off. At closed position you should have .98 v. Try adjusting it. May be bad!
Old Aug 17, 2006 | 08:53 AM
gixxer1's Avatar
gixxer1
its a brand new ford tps,it will not read a volt no matter what i try,full throttle or closed.........
Old Aug 17, 2006 | 01:49 PM
greenstreak9205's Avatar
greenstreak9205
the tps shouldnt b the problem if it runs fine (when it starts). if the tps was bad then the idle would b off, part throttle input would stutter...somthin like that. correct? i just got the same problem with mine. It starts fine (when engine is cold) no extended cranking or anything, but once it warms up it just wont go. i also have fuel and spark so thats all fine. what would the car do when the module is bad? does it not start at all, or is it just when its warmed up?
Old Aug 22, 2006 | 09:56 AM
gixxer1's Avatar
gixxer1
finally figured out problem, i had a bad computer, make that 2 bad computers!(what the f@%&!)so i bought a reman. computer and now car is fixed,thank god!!!
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
