Why is my engine running soo hot?
#21
RE: Why is my engine running soo hot?
yea, like twotonevert said, check it with an external gauge before blaming it on the cooling system. I had no idea it was a stock gauge or that would have been my first suspect, just take one of those long thermometers like you use in a turkey and stick it in the radiator. That should give you an idea of where you are on heat.
#24
As long as the engine at operating temp, the wax stays melted in the, "pill box", and the t-stat is open. When the engine cools, the wax hardens and closes the t-stat. It is supposed to be accurate to within 2 degrees. However, it says right on the packaging, race use only. So, I dont know, I am grasping here.
HIS S-197
08-10-2015 05:47 PM
