oxygen sensor tool?
oxygen sensor tool?
What tool is there to remove the Oxygem sensor in 87-93 5.0's? Because theres no way mines coming out on an auto car without a special tool. I have seen the socket with the slot but i am not even sure if that would work.... Thanks
RE: oxygen sensor tool?
i used an open end wrench on mine... worked fine. I have an auto, there werent any special tools needed...
It took me approximately 90 seconds to replace both oxygen sensors just using an ordinary wrench. Seemed like one of the easier things to do. Then again, I have the sn95 so maybe something is slightly different in yours.
i dont knwo how you guys ar euseing a wrench on the pass. sife i cant even fit a box and on let alone have room to swing it and the driver side i can get it on but there is no room to swing a 7/8" wrench.
oh scratch that, sorry i took my h pipe off with the 02 sonsors on it, just unplugged em when i switched it to an o/r H then bolted em in my new o/r H nd bolted that up then plugged em into the wiring again. sorry havent done it with the h pipe still on....[&o]
