No power over 3000 RPM??
Old 08-28-2006, 03:58 PM
rayzor_187
rayzor_187's Avatar
Default No power over 3000 RPM??
Hi
Here comes a question from a frustrated swede.
I have a Mustang -94 GT 5.0 with a strange problem.
It starts up and runs smooth on idle and below 2500 RPM's. but...
As soon as i push it towards 3000 RPM's and above it becomes lame!
No power at all, it take's about 20 sec to rev it up to 5000 RPM's on 2'nd gear with full throttle!!
Also the check engine comes on now and then (have not been able to read out the codes).
Any suggestions??
rayzor_187 is offline
Old 08-28-2006, 03:59 PM
PX429
PX429's Avatar
Default RE: No power over 3000 RPM??
keep working with the OBDI
PX429 is offline
Old 08-28-2006, 04:09 PM
rayzor_187
rayzor_187's Avatar
Are there any good links to where i can buy a OBD I unit or is i any DYI on these things??
Old 08-28-2006, 04:14 PM
92GreyGT
92GreyGT's Avatar
You should make sure that your spout connector is in. It sounds like your timing isn't advancing. Have you or anyone tried bumping the timing?
92GreyGT is offline
Old 08-28-2006, 04:23 PM
rayzor_187
rayzor_187's Avatar
OK... two dumb questions from one dumb swede...
What and where are the spout connector?
How do i bump the timing?
... it's soo much easier to fix my stang -70.
// Jimmy from Sweden
Old 08-28-2006, 04:36 PM
92GreyGT
92GreyGT's Avatar
The spout connector is in the wiring that is going to the distributor. It will be hanging somewhere near the wiring harness that's plugged into the distributor. It is just a small plastic grey jumper so to speak. You have to remove that to set your timing. Once you set the timing put it back in. If it's gone your timing won't advance.
92GreyGT is offline
Old 08-28-2006, 04:39 PM
PX429
PX429's Avatar
Spout connector is under your MAF
PX429 is offline
Old 08-28-2006, 04:40 PM
89GTRed
89GTRed's Avatar
this is your spout pull the plug but dont lose it![]
[IMG]local://upfiles/32142/BBD6E418A8664A848C7DBA04ECAD9DD1.jpg[/IMG]
[IMG]local://upfiles/32142/E4282B6B91ED4AB184E28D3A2FD46A2A.jpg[/IMG]
89GTRed is offline
Old 08-28-2006, 04:41 PM
PX429
PX429's Avatar
it's a 94
ORIGINAL: 89GTRed
PX429 is offline
Old 08-28-2006, 04:42 PM
89GTRed
89GTRed's Avatar
oops my bad.
89GTRed is offline
Quick Reply: No power over 3000 RPM??
