speedometer help
hmmm i put on my speedomer on but now the needles dont work, the lights on the speedometer work the stock ones but the needles dont also the lights that say for example Check engine parking brake on low coolant and such dotn work at all not even with my e brake on, any body know the fuse location for this, or what may be rong with it, i dont have my manual i have a 94 mustang
i have a 94 stang to and my whole tachometer speedometer gas/ battery guages went out. after emissions testing. and its underneath your steering columb. the other fuse box is located behind you batter in a black electronic looking box. ill have to get back to you exactly which fuse.. cause its bedtime 3am :P
OK I FOUND MY MUSTANG MANUAL AND I CHECKED THE FUSED THAT HAVE TO DO WITH THE CLUSTER BUT THEIR ALL WORKING, THE CLUSTER LIGHTS WORK AS WELL BUT NOT THE ACTUALY GUAGES(NEEDLES) ANY ONE HAVE AN IDEA OF WHAT IT COULD BE NOW?
i just found out that my brake lights dont work either, when i press the brake a lil bit less that half way they work but if i press the brake more they turn off any body know why? plz i need to fix this along with my cluster
