Just installed what do you think
Well i just finished up the Trick Flow AC and Smog delete kit. Also converted to Twin 12 inch electric fans. They are controlled by a relay and thermal probe. The fans are set up as a pushers and hidden infront of the radiator so they cannot be seen. All you can see is the tabs for the mounts. There is a ton of room infront of the motor now. The kit was great bolted right up plus the but dyno can already feel the diff. Here are a could of pix let let know what you guys think. Smog pump is still installed in the pix but it is bypassed. It is all the way out now. I had a hard time getting that top bolt out. Took myself and a friend to get it all the way out.
RE: Just installed what do you think
ORIGINAL: drowned_buddha
looks good....cleaner. Now you just need some Techflex to clean up that wiring nightmare you got goin on.
by the way here is what the motor looked like before today.
09-10-2015 08:39 PM
