blaster 2 coil
just got my coil and tried to put it in put ran into a couple of problems.
first off, is my '92 mustang TFI? what is TFI?
if its not TFI, then i need to use the ballast resister right?
next, it says the i have to hook up the positive and negative wires to the coil. the directions say that positive is usually red/light green and the negative is dark green/yellow. i have the red/light green, but the other wire is yellow and tan. in the diagram it shows the positive wire is closest to the fender and the negative is farther from the fender. but heres my problem, in the picture it shows the red/light green wire (positive) nearest the fender, but on my car, the red/light green wire is the farther from the fender. so heres my question, which wire is the positive wire and which is the negative wire?
