My shift points
Old Sep 3, 2006 | 09:23 PM
Twotone93stang's Avatar
Twotone93stang
Default My shift points
I have a 1993 ford gt mustang and it shifts way to early flooring it. How do I adjust my shift point to make it higher?
Old Sep 3, 2006 | 09:26 PM
Pure5.0's Avatar
Pure5.0
Default RE: My shift points
Im assuming its automatic...and what is too early? Stock its supposed to shift around 5500 i think...dont have an AOD but just from what I have read.
Old Sep 3, 2006 | 09:33 PM
Twotone93stang
flooring it my car shifts at 3500 rpms. Yes the car is automatic. I would like to know how to adjust the shift points to make it 5000 or 5500
Old Sep 3, 2006 | 09:37 PM
Pure5.0's Avatar
Pure5.0
Check your vacuum lines. Sounds like your tranny is not getting the right vacuum causing it to not know when the car is WOT....
That is if our cars use that type of shifting for AOD. Other cars use elctronic control for their solenoids, and some use a lever that your gas pedal moves.
It is either the lever or vacuum.
Old Sep 3, 2006 | 10:43 PM
deadcarnahans's Avatar
deadcarnahans
Most shift kits do not come with this part. You can fabricate it yourself though. It's just a spacer with a .250 hole inside, about .350 on the outside and the thickness will vary. I installed one that was .080 thick and I did not think the tranny was going to shift at all, but it did around 6000 and the tires really barked good.
I did go back in and install a thinner one, about .050 more suitable to my driving style.
See attached photo.
This is the TV limit valve. It is in bore # 6. Yes you will have to remove the valve body, bummer.
Remove the valve and spring, install your spacer on the valve and then the spring, reinstall the three pieces into the bore.
You might as well do a full kit while you are in there. I have had good luck with B+M but Baumann is the one that can provide the spacer if you don't want to make one yourself.
[IMG]local://upfiles/36086/3D01AB86135644CA9A87574A7DC9FD35.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
