Manual Valve Body
RE: Manual Valve Body
Easy as hell to figure out and you will get used to it in about 15 seconds. Just make sure you don't screw up like I did at first. Make sure both the tranny AND the shifter are in N (or at least the same gear) when reconnecting everything. I pulled the cable a bit too hard underneath and moved the shifter off by one gear, LoL. Had to disconnect everything and reset it.
But it was seriously easy to install and very easy to get used to. Fun to drive too!
To be honest, they would probably know better than me or most others. Give them a call and tell them exactly what your setup is. They should know their product pretty well and will be able to tell you exactly what you need.
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
