reverse grinding?
reverse grinding?
91 gt convertable 5 speed
almost everytime i put it into reverse it grinds, no other gears do this, just reverse
and putting it into 1st and second once ina while is tough, u have to push it hard sometimes to get it into gear
why is this? and how can i fix it?
RE: reverse grinding?
as far as the reverse thing, throw it in a forward gear first, then reverse... i had that problem, i usually go into 5th then down to R and no grinding
the reverse gear is not syncronized. if you are moving even slightly, it will grind.
Never seen a T5 that didn't grind reverse... Like the others, I go into 5th first... I've seen several that are a little tough in 1st too, try pulling the clutch back out and in before you force it in, Don't want to bend your shift forks...
KingRando
10-02-2015 08:06 AM
JDWalton
09-24-2015 08:47 PM
