Clutch Help...... Plz
i have a real bad like metal to metal sound when im at higher rpms and let of the gas.. but when i push in the clutch pedal it go's away.. and it dose it reallly lightly at low rpms. well im thinkn of buyn a whole new clutch kit.. and i was lookn at the Ford Racing HD King Cobra clutch... is this clutch any good? and how much u think this clutch can take?... thanks guys Mike.
RE: Clutch Help...... Plz
mm u thnk spec clutchs are pretty good.. ive never actually been in a car with one or heard alot bout them.. but on there site its sayn there a good clutch.. ill check them out.. right now i have a centerforce stage 2 and its done.. slips in 3rd so bad.. and i know its to small of aclutch so i was ganna buy the dual friction centerforce clutch. but the spec 3 sounds like a good deal also.. anyone else have any suggestions?..
If it is a pilot bearing, you should be able to affect the noise without having to fully depress the clutch. Mine rattles but when I just rest my foot on the pedal it will go away. Worse ones take slightly more pressure. Describe the noise a bit better and I can probabaly give you good help. I give ford techs advice for a living so I am willing to help when I can.
I have the king cobra and it grabs hard enough for what I could ever throw at it. I know guys putting almost 400 at the wheels on the stock clutch with minimal problems. The king SUCKS in ANY traffic. No lie, I fear I will break the cable and/or pedal one of these days. It is that stiff.
dam.. ya i wont be buyn a king lol.. cuz its my daily driver.. but ok its like a bad bearing in a wheel sound.. its like a metal to metal with out oil inbetween.. **** hard to explain.. its just a loud rubin noise like metal is rubn metal its when theres a lot of tourqe and i let up.. liek at 4 tousand and let of the car jerks ya now and thats when its just liek real loud
Okay. A worn pilot bearing will make noise similar to when a U-joint does; when there are sudden speed changes in torque transfer. On engine braking and throttle blips. Most of the time you have endplay problems when you have pilot bearing problems. The biggest thing that happens when you depress the clutch is take the driveline out of the mix. Your problem may lie in the trans. Noises are the toughest part of what I do. Sometimes I have the guy take the phone in the car with him...
When you push the cluth in and hold it in, the pilot bearing would still spin on the transmission input shaft so if it was bad it should still make noise. If it is the clutch release bearing that is bad then pulling the trans and checking or trying to see through the cluth fork cover would be a pain but worth it to know for sure.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
