turbo or supercharger
RE: turbo or supercharger
ORIGINAL: RacquetballRyan
Care to explain everything that goes into building a turbo system?
I don't want to hi-jack the thread over this, so feel free to start a new one.
Its a valid question/topic.
With a Turbo, you can have as much power as you want. You just get the Turbo that will give it to you, and build around it. Check out this dudes crazy race setup. http://www.turbomustangs.com/smf/ind...?topic=68023.0
Go here! http://www.turbomustangs.com/smf/
I have a turbo kit on my car, T66 intercooled. Iam probably going to start making headers or possibly kits with a buddy of mine. I also am tired of having to spend an arm and a leg for turbo stuff so we want to start are own stuff. I can get at all my plugs without removing any pipes or any swivels and thats what i like. I turned the intake around and have a blow through intercooler.
ORIGINAL: blazinyellowbeast
And is building your own turbo kit worth the headache, rather than buying one. Just wondering, I have no expierence with turbos.
Besides, it's something I'd like to do; another car project. Anything worth having is worth the effort to get it. There's plenty of info and parts out there to do this stuff. The September issue of Hot Rod was great! This dude Tom Nelson built a 406 Twin Turbo that makes 1000hp on pump gas, and idles at 700 rpm! And that's a motor with driveability. With race gas it made 1500hp! My motor idles at 1000 rpms, and drives like ****e!
I can use the stock 5.0 cam, and I'll have great driveability and mileage, and big power if I want it. I want a motor with big power, but with manners. Turbo is the way. You can run a small duration cam, and cruise around staying out of the boost, and your car will purr like a kitten. It's not like having a big stinky NA race cam that burns your eyes with gas fumes, and stinks up your clothes. THen when I load up the motor, the boost comes in and it game on.
Check this out.
http://www.hotrod.com/techarticles/e...ion/index.html
http://www.hotrod.com/techarticles/e...ent/index.html
First off if someone tells you its simple to build dont believe them. You will get tired of cutting and welding pipes quickly. I spent about 2 weeks and made custom headers not those flip around ones everyone uses and they have to move the p/s up to the a/c area. Then you have the downpipe to make and the wastegate to weld in. I thought it was simple at first also then 2 weeks later i thought different. Then you need injectors, fuel pump, blow off valve, wideband o2 sensor, chip or preferred standalone computer, wastegate, plugs, coil and spark enhansor(msd),fuel pressure regulator, larger radiator and a diaper for when you soil your pants when the boost hits. Its deffinaltely cheaper for a supercharger but turbos rule.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
