Torque Link
Old Sep 11, 2006 | 11:28 AM
88BlueGT's Avatar
88BlueGT
Default Torque Link
I never hear of people using torque links. They seem like they could make a difference and they are only like $55 bucks! Does anyone use this? Do you recommend it?
Also, I know that they hook up to the heads and where the sway bar bolts to. So does that mean that I cant run a sway bar if I run the torque link? Thanks.
http://store.summitracing.com/egnsea...3&autoview=sku
Old Sep 11, 2006 | 01:06 PM
88BlueGT's Avatar
88BlueGT
Default RE: Torque Link
Noone? Why the hell is the forums so slow today!? [:@]
Old Sep 11, 2006 | 01:16 PM
P Zero's Avatar
P Zero
Cuz it s my birthday, YAY~!
Its basically a fancy chain. People used to tie their engines down with chains, basically to simulate a solid motor mount. Thats what that is, its just fancy. And all youd have to do when you go to the track is pop a pin in and wualla you have solid motor mounts. Which help x-fer more torque/hp to the ground.
-P.
Old Sep 11, 2006 | 01:42 PM
88BlueGT's Avatar
88BlueGT
WELL HAPPY BIRTHDAY!!! How old are ya today?
Also, so you think its worth the $55 bucks? Also, so would I be able to use my sway bar when using this? Because I would like to keep the brackets up and just remove the brace for the street and than when racing pop it back in. But If I cannot use my sway bar than Im not going to get it....
Old Sep 11, 2006 | 01:51 PM
7upedition's Avatar
7upedition
i've seen these before at the track but haven't looked below to see how they mount, i also dont have any personal experience but i would think you could use a longer bolt to connect the sway bar or else have a double mount fab'd up somehow. good luck blue
Old Sep 11, 2006 | 01:54 PM
grabbem88's Avatar
grabbem88
ah just get solid m/m's...........
Old Sep 11, 2006 | 03:59 PM
88BlueGT's Avatar
88BlueGT
^^ For a street car?!?!? Helllllllllll no. Ill pass
Old Sep 11, 2006 | 04:18 PM
grabbem88's Avatar
grabbem88
why not mines a street car it's not that bad.
Old Sep 11, 2006 | 08:46 PM
luckythirteen13's Avatar
luckythirteen13
i have a torque link on my car. i keep it hooked up all the time even when im on the street. it didnt cause any more vibrations like most people think. i guess its a good compramise between rubber mounts and solid mounts. i got it because i was tired of my motor slamming my hood every time i took off. i have two small dents in my hood where the tb hit the underside of the hood and i have a couple of deep scratches on my intake manifold from the motor torquing over and slamming it. you can run a sway bar with the torque link. i did for a while then i just got rid of the sway bar all together. plus with my hp, a high stall, 3.73's and a slicks, the stock mounts wouldnt have lasted
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
flash_xx
Oct 16, 2015 07:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
