Installing a fan clutch?
How do I install one of these and is that my problem? I start the car and run it and the fan is damn loud, but I was told the fan clutch was replaced recently? Was it installed wrong or what? Is this hard to do and how long does it take? Thanks for your help.
RE: Installing a fan clutch?
fan cluth is the shaft and crap on the fan. it ingages at a set temp and turns the fan 1to1 with the water pump a bad fan cluth will make your car run hot(not good). to test it get your vcar hot and if you can turn teh fan its bad, FAN = white thing with fan blades in front of the engine, will spin freely if car is not hot(warmed uped)
CAUTION: turn car off before attempting to turn fan by hand!!!!!!!!!!!
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
