MM Panhard Bar
#21
RE: MM Panhard Bar
I've had my K member for like a year now just sitting in my garage. I just have so many other things I want to buy lol
after I buy these two things in my garage I will have:
MM Subframes
MM Panhard Bar
TF Street Heat Manifold w/ install kit
2800 Stall TC
D&D K Member
New Carpet
3.90's w/ install kit
And im sure prob 10 other little things Im not thinking about.
MM Subframes
MM Panhard Bar
2800 Stall TC
D&D K Member
New Carpet
#23
RE: MM Panhard Bar
It wouldnt last one run with that setup lol
Also, yea I know but Im waiting for other things. Im not gonna install the TC until I get a new trans. Im not gonna install the k member until I get my coil over and a arms. Im not gonna install the manifold until I get my blower, tb and maf. and the gears... well no excuse for the gears. I just havent been able to find anyone to install them for under $300.
#24
RE: MM Panhard Bar
actually a dart block and that 347 and that turbo with proper tune would be perfect push round 750RWHP or so,, should hold it, when you regear that rear end put in a new posi like an eaton or something, then get you some c clip elims unless you trust your c clips with lots of power i dont, or if you have disc dont worry about the c clip emils,, yeah sucks to put together an 8.8" but i hav edone it myself and not worth the trouble or money saved not getting the shims right
#26
RE: MM Panhard Bar
well see thats the problem is that if i did do the turbo id be pulling this brand new 347 apart and puttin it in a dart block, so you are correct it would blow a stocker to hell and back, be fun though
#27
RE: MM Panhard Bar
Blue, definitely grab the panhard bar. The info stated earlier is correct. You will want to install the subs first b/c they are one of the mounting points for it. It keeps the rearend centered under load and cornering.
Damn you and all your friggin luck....50 for the track heat, 200 for MM subs and panhard NEW....... [:@]
If you ever want a silver street heat upper instead, lemme know and I'll trade you straight up. I'm gonna need the track heat here before too long....either that or port out my upper/lower....
