CODE 113 WHAT IS THIS????
Old Sep 22, 2006 | 05:37 PM
KILLA E's Avatar
KILLA E
Default CODE 113 WHAT IS THIS????
Anyone else out there ever had code 113 (intake air charge temperature sensor above maximum voltage / -40 degree indicated) come from their code reader? its my only code and the car runs but the code reader book says that if code 998 comes up,the car is running in failure mode and that the computer is using this code to keep the car running and that the car is running at a minimal level and repairs should be made as soon as possible..... any input? thanks guys!
Old Sep 22, 2006 | 05:47 PM
4fit?'s Avatar
4fit?
Default RE: CODE 113 WHAT IS THIS????
That the IAC located on the side of the tb (on fox cars anyway, don't know about SN95s). They aren't the cheapest things in the world (around $60-70), so get with a buddy that has one and borrow his and bolt it up. See if the code disappears. If so, pick you up a new IAC.
Old Oct 11, 2006 | 11:37 PM
HAUS's Avatar
HAUS
ORIGINAL: 4fit?
hes talking about a ACT. aircharge temp. sensor. IAC is the Idle Air Control Valve.
the max volts should only be 4.6 and the code shows that the signal is greater then the max volts.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
