3:73 gears, I have 2 questions...sorta
1. I installed 3.73 in my 95 today it used to have 2.73 what spedo gear do I need to compensate for speedo?
2. When I get to 110 mph I loosew power in a major way, is that right around fuel cutoff for a FOX?
I swapped/wired in a9l pcm and harness. 95 5.0 with a better pcm! What is involved in the fuel cut off process? Does it cut timing?injection?spark?
RE: 3:73 gears, I have 2 questions...sorta
Part no for the spedo gear? Cool. I have never had this problem till I installed the gears, I had it to 125 before many times with no problems. Does the FOX pcm have a fuel shut off?
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
