cheap but good 5 lug conversion???
RE: cheap but good 5 lug conversion???
Did mine for roughly $200.. Includes bigger calipers as they were only $15 a piece
Here ya go:
two driver axels out a 83-92 ranger, drums for it too
and
Pair of rotors for a late 80's mark VII
Go to a wrecker, get the axels, then buy new brake parts. And with the money you saved, pick up a set of late 80's lincoln calipers, they're 73mm, replace your stock 60mm ones. Cost me $30 for the calipers (cheap as a mofu) and roughly $125 for everything else involved in the conversion + $30 for wheel spacers & $50 for lugs because I put bullits on it.
Came out nicely for a $125 deal i must say...
And here's the final result:
[IMG]local://upfiles/16761/CDF1A20CA0ED4BEDA9635A38454AA4E5.jpg[/IMG]
Here ya go:
and
nice job liquid, in my opinion the 5 lug is 90% for looks and wheel choice, if you really want a wheel that only comes in 5 lug then go ahead and switch over, dont get em wrong i like the converion but i don't think its needed in all cases. however there are several threads and i beleive a sticky on the conversion. good luck
i think you can use like 87 ranger ft rotors and keep the same calbiers, for rear like stated above ranger dr. axle and and brake drums... i do have btw a driver side axle and both rear drums drums in perfect cond. has for brakes you can keep the rear ones you got . pm me if you want the parts cheap. you will just need a extra ranger dr. axle
cheap and good? This is your brake system we are talking about...
If you are going to 5 lug, is it due to wheel choice? If so, the wheels will decide on the conversion. (for FORD Wheels atleast)
Go here...
5 lug conversion
Go here...
5 lug conversion
ORIGINAL: 7upedition
ORIGINAL: CarJway
Go here...
5 lug conversion
Go here...
5 lug conversion
ORIGINAL: primetime5.0
if you just do rotors you will need spacers to clear most wheels
11-10-2015 11:39 AM
mungodrums
10-07-2015 04:01 AM
