Tried everything i know!
RE: Tried everything i know!
Thats a toughie...i guess take the positive battery cable off of the battery for a few minutes and that should reset your computer. Then see where your at, check the air filter to and if your air silencer is in there, try making sure nothing is up in there blocking it.
Clean the MAF anyways, sometimes they come dirty, just spray some electical parts cleaner on it and gently wipe it with a Q-tip.
How does it act when warm? Checked for a vacuum leak?
Do you have a timing light or a friend of yours have one? If so then you can put it on each of the plug wires while it's idling for consistant spark to see if the reason it's doing this is in the ignition somewhere.
& the free simple check for a blown headgasket, take the radiator cap off WHEN THE ENGINES COLD & start it. See if any fluid comes out, hopefully it won't.
How are the O2's?
How are the O2's?
I'll try cleaning the MAF and i am going to go get new O2 sensors, hopefully that will fix it. If not then I guess I will just have to deal with it?
When it it warm it just has a rough idle like it has a bigger cam, cant find any vaccum leaks, i'll ckeck with the timing light tomorrow. and the head gasket is ok, i tried that today.
ORIGINAL: Longhorn80
Try checking the dizzy shaft for play, as i remember, a friend of mine had something like this happening to his car. It was missing but he wasnt noticing it, it just idled nasty as you've said. But we checked his dizzy and the shaft would move about 1/8 either way. The bearings were gone.
But also, try cleaning the 02's first. Just burn them with a torch until they turn white.
You should also check ur fuel pressure.
https://mustangforums.com/m_563238/tm.htm
go to this link and look and number 45 its the barometric pressure sensor i was telling you about
usually cleaning the IAC motor will do more harm then good. My car idled fine until i used electric motor and brake cleaner on my IAC.... then it ran like crap. I replaced the IAC and all my problems went away
