pulled some codes for detonation problem
so i've been detonating in the number six cylinder (my guess foing off the spark plug readings) and i just pulled some codes since my CEL had been on constantly.
i used KOEO by jumping the STI and jumper.
I got 63 ---63----34----63----96----34. does this mean anything to anyone? i tried searching google. help pease i want to fix it..
thanks
thanks
ORIGINAL: fordguy17
thanks
thanks
34 - EGR Valve Position Voltage Above Closed Limit (O,R), EVP circuit has intermittently failed above the closed limit of 0.67 volts (M)
96 - Fuel Pump Circuit Open-Battery To PCM (M,O)
Start with the TPS, check its output voltage at closed throttle (.7-1.0vdc is OK), and its voltage range by slowly opening it to WOT, key on engine off....
For code 34, the EVP might need to be replaced.....is the EGR still operational?....
Code 96.....do a clear codes and check if it reappears...
cool.
will check tps. egr is gone and has been.
what exactly does 96 mean? the car runs fine unless you put it under load...
will clear codes.
thanks man.
will clear codes.
thanks man.
bryan616fl
Jan 25, 2019 09:07 PM
